Bigblueblues
- 2003 mazda6 4cyl
The other windows didn't work either but I read on this forum how to reprogram them. All windows work except the drivers window. It doesn't go up or down. I took the door panel off and checked the regulator. It's fine but when I push down or pull up the switch the motor doesn't move. I figured it was shot so I switched out the rear right motor and it doesn't work with the drivers window switch. Could the switch go bad just like that? I had it all the way down when I changed the battery
