So i put the spark plugs in without issue. Started her up and everything seemed good, but ive noticed that the AFR is kind of unstable. The idle and cruise AFR goes between 14.3 and 15.3 back and forth as it kind of searches constantly. There isnt much knock at all but im a bit concerned about why the AFR does that. It was MUCH more stable with the stock plugs. Also, i compared the densos to the stock plugs and noticed that they are shorter! The stock plugs are prob 1/4" longer than the densos. Not sure why these are shown as direct replacements when this is the case. The gaps were all good to go with the plugs so that wasnt it. Anyone else encountered this??
