What I have done since day one on hot days to alleviate the problem is: Turn on the AC, set to 60 degrees set temp, turn on fan to middle speed, air direction face only. Let the AC do its thing for about three or so minutes, basically until the air coming from the vents is frosty cold. Turn off AC, leave set temp at 60 degrees, air direction at face only. The dashboard on these cars is such a huge expanse of black, heat-soaking plastic that the dash vents get hopelessly heat-soaked sitting in the sun. I have found that by running the AC long enough to "cool" the plastic that the air passes through I can drastically reduce the effect you are describing. Try it out one day, I think you will find this technique works quite well on all but the hottest of days. HTH
