I'd upgraded from version Fred.0.Flintstone to 70.00.21 with no problems, using AIO tweaks to fix a couple of niggles (lockout!). Was frustrated with lots of bugs with Carplay, like relentless crashes. So bumped up to 367A.
All went fine -- except I've now lost some forward sensing camera system functionality.
It manifests as three amber warning lights in the dash ... Smart Brake Support (SBS/SCBS), Lane Departure Warning (LDWS) and Adaptive LED Headlights Warning. The camera system itself is still partially working it seems (rain sensing wipers, traffic sign recognition).
Anyone else had this problem?
I did a re-install of firmware, reset ECU, rebooted, turned off everything I could in Connect, etc etc. Left battery disconnected for a few hours...
I'm not sure if it's the firmware update itself or the fact that when I do a firmware update it drains the battery almost flat (solenoid barely engages if I try start). There is a TSB that describes this identical behaviour at https://testing-public.carmd.com/Tsb/Download/131817/SI117886:
My VIN is higher than the TSB refers (JM6KF***...), and to do this fix requires booking in to a dealer to get in special kit and probably lots of dollars. So not keen on that.
Any silver bullets?
DESCRIPTION
Some vehicles may experience a SBS/SCBS, LAS/LDWS and/or ADAPTIVE LED headlight /HBC warning light on with the DTC U0155:00 stored in memory. The warning lights may stay on while these functions are deactivated.
DTC U0155:00 - Communication error to instrument cluster.
This concern may be caused by faulty Instrument Cluster software. To eliminate this concern, the software has been modified.
Any silver bullets?
