NeverSober said:Im with turf.......yea you freeze them they get closer.........but then take them out of the freezer what happens? It goes back to how it was..............
using basic logic this would be an wise assumption.... but lets think about something.... you make steel form iron ore... using heat... they are using the temp to remove /add carbon depending on what type of steel. With that in mind... the heat causes material to expand and thats how impureitys are removed... depending on how fast that material is cooled with effect its rigidness its tensile strngth brittleness etc. so... cooling has simialr ways of effecting the metal but in a different manner. We are not talking about ice/water/ and water vapor... where if you freeze water you get ice etc and when it warms back up its "water".... Steel is a solid not a frozen liquid. There for it is effected diffrently under different stress's i.e a slow cool will allow for differnt chemical and covalent bonds to form/break down... a super cool ro supper heat will have similar effects... i m not sure if i made this any clearer but... jsut know its not like what we think of when we thin of "ice" and water etc. besides! WATER expands when frozen... so if you use that logic none of this will make scense
Chad
