- 92 & 16 Meyatas
haha...dark side..dark side..dark side!!(rockon)no you don't! you want to follow the link in my sig, and win that
i'll add some automagic rule changes to make it a little easier for you if you like
friendly recruiting....... (actually, he contacted me!)Turbo guys recruiting in the NA section again? ... hrmm.
I appreciate it bro, but to be honest, it's all about bang for the buck.
$ and HP. Neither of which I have.
Tho conceptually, I love the NA challenge, anyone with the resources to try and chase that already KNOWS they should pick a more solid platform.
Believe me, I would love to see a FE3 swap and proper build up.
NA or a huge turbo build that fender mat is totally true!! I am willing to bet I have one of the top 5 protege's with the $ amt spent and not counting sponsor payment I bet I am in the top 2(No sponsors here!! )
Rob
OK, update:
Cylinder head will be decked, inspected, valve and valve seat work at machine shop, in/exh port clean up at C & C Fabrication.
Setup for cams, adj cam gears, pulleys (UDCP, Alt, WP, PS).
Coil off plug conversion and 626 valve cover.
Update FIC firmware to Beta version. (See FIC thread for updates).
Need a WB to hook up.
Picking up set of P5 wheels locally (to be painted white).
Thinking about getting some quotes on powder coating.
My AWR links look like they've been undersea for eons.
Considering VC and wheels for coating too.
Prolly need a few things for cylinder head swap.
Got the gaskets for VC, crank pulley and cams.
I think I may want t-belt, tensioner and a fresh head gasket.
What else?
I need a tranny flush.
Sorry I'm just stuck on those numbers......at 90whp, that means you are losing almost 70% of your stock HP.....I don't know I guess I'm a tard.
Also going in with cut 626 VC
this might help, traced the cut out i wanted then cut it with a dremel...cake!Have you pics of how you cut the 626 valve cover?
^^Can you use that as a long term solution or is it best to replace the valve cover with a full valve cover once you've dyno tuned the cam settings?
Yes this is permanent. The cut portion doesn't interupt the VC seal.
The important part for us is having the CPS mounting intact.
Otherwise u could cut it all off.
