its very easy to do.. you don't even need pics to follow to do this
basically a cracked lens happened on some cars and there's a TSB for that
to replace it, get a stubby phillips screwdriver... you will see 2 screws at the top of the gauge hood (the black plastic surround piece)... remove them...
tilt the steering wheel to the lowest position... then reach in around the top of the steering column and grab the bottom portion of the gauge hood piece (where it is cut out around the steering column) and pull out... then the whole gauge hood will come out... it may take a little bit of fidgeting to get it out between the dashboard and steering wheel
then you'll need a longer phillips screwdriver to take off the screws... there's 3 of them... one at the top center on a metal bracket, and then there's 2 at the bottom on the white plastic portion of the gauge cluster... once you take these out the cluster will come out.... unplug the cluster by reaching into the back and squeezing the tabs on the plugs to get them out.... be sure to cover the steering column and steering wheel with a rag because the metal bracket on the cluster may scratch them!
the plastic lense is snapped in place... you just need to push down on them to get it off... you'll know what I mean once you look at it
it's really a 30 minute job!
