mitchellmtch
- Mazda speed 3
Does anyone know any tuning places near north jersey, that can tune a mazda speed 3 using cpe standback. WIll drive a couple hours if have to
there is a place by me in edison that does tuning called turbo trix racing
had a friend go there in his turbo'd galant. when he got the car back none of the windows would roll up/down, stereo wouldnt work, and countless other problems.
Don't kid yourself, that s*** probably never worked on his galant before that. It is a Mitsubishi after all. . .. (band2)
+1 darksun is right find laloosh. or, get your dashhawk and start doing datalogs and find out where the car knocks and goes too rich/lean and slowly start making tweaks to your maps and get the car runnin right
13afr at 4000 rpm? your nuts man this aint no BMw disi. I want 11.8 (11.5-12.0) at wot on my SB with some fuel added down low and timing pulled, then added timing up top with some fuel pulled. Tweak the MAF x-fer tables and dial in the fuel trims and go have fun. It's not hard to do if you have time
