machine shop
yea your gonna have to get the crank turned and get oversize bearings if you scarred the crank too much
as for the clearances, i dont have them on me unfortunately, if i was at home i could help you out..
The FS engine manual has the information.
Rod bearing oil clearance, standard (.001"-.0026") Maximum (.0026")
Rod bolt torque is done in a sequence of steps.
1. Tighten in 2-3 steps to 16.3-19.8 ft.lbf
2. Put a mark on each bolt head.
3. Using the mark as a reference, tighten the bolts by turning each 85-95 degrees.
Note degrees not ft. lb.
The engine manual does suggest using plastigauge to check oil clearance.
Clifton
