I've been searching around reading stuff and googling. I'm confused.
NEED: roll bar rollover protection so I can autox and do track days (including SCCA and NASA events). NO head to head racing. Still daily drive it.
REQUIREMENTS:
- approved for SCCA and NASA autox and track day events
- NOT a cage
- allows full usage of seat all the way back
- allows full usage of soft top
- will accommodate a hard top in the future
- bonus: allows wind deflector
- IMPORTANT: need to please the wife... so keep the aesthetics in check as much as possible (while still doing the job)
WHAT I FOUND:
- Two names: Hard Dog and Boss Frog seem to be the trusted ones, approved, and readily available.
- will be a 4 connection
QUESTIONS:
- difference between bolt in and welded? (I'm willing to install myself if it's a bolt in. I've installed sway bars, susp springs, struts, bolt in bracing, brakes pads/rotors/fluid, and intakes on other cars before)
- are double hoops safe? are they as stiff as a single hoop?
- difference between Hard Dog and Boss Frog?
- should this be installed professionally?
- Which model Hard Dog or Boss Frog?
REQUIREMENTS:
- NOT a cage
WHAT I FOUND:
QUESTIONS:
