Hi,
I have 3 oil SPECS here. Anyone can tell me what the best one to use in my mazda protege 2.0L Turbo-converted engine running on 11PSI?
Oil 1:
Viscosity, Kinematic, cSt
at 40oC: 108
at 100oC: 18.7
Viscosity Index: 194
Cold Cranking Viscosity, cP at -35oC: 5770
HT/HS Viscosity, cP at 150oC: 4.4
Zinc, Mass %: 0.125
Phosphorus, Mass %: 0.113
Sulphated Ash, mass %: 1.41
Base Number, mass %: 9.9
Oil 2:
Viscosity @ 100C, cSt (ASTM D445): 11.0
Viscosity, @ 40C, cSt (ASTM D445): 61.7
Viscosity Index: 172
Sulfated Ash, wt% (ASTM D874): 0.8
HTHS Viscosity, mPas @ 150C (ASTM D4683): 3.1
Pour Point, C (ASTM D97): -42
Flash Point, C (ASTM D92): 230
Density @15.6 C, mg/l (ASTM D4052): 0.855
Oil 3:
Viscosity, cSt (ASTM D445)
@ 40 C: 75
@ 100 C: 13.5
Viscosity Index: 185
MRV at -40C, cP (ASTM D4684): 31,000
HTHS Viscosity, mPas @ 150C, (ASTM D4683): 3.8
Total Base Number (ASTM D2896): 11.8
Sulfated Ash, wt% (ASTM D874): 1.3
Phosphorous, wt% (ASTM D4981): 0.1
Density @15.6 C, g/ml (ASTM D4052): 0.85
Out of the 3 oil, which one will be the best for a mazda 323 protege year 2003 turbo converted 2.0L engine running on 11PSI and which is it the best as well?
Thanks a lot..
Oil 1:
at 40oC: 108
at 100oC: 18.7
Zinc, Mass %: 0.125
Oil 2:
Oil 3:
@ 40 C: 75
@ 100 C: 13.5
Thanks a lot..
