No, I stuck it on a dyno, had the professionals attach the data signals to the engine and the sniffer probe up the exhaust. I then did 3 full throttle runs from 2500 RPMs to 6500 rpms while video taping the computer screen to see real time A/F ratios throughout the entire RPM range. In all three runs the A/F ratio was pegged at the lowest setting it could register - 10 - from 2800 RPMs all the way to just over 6000 RPMs. From 6000 RPMs to 6500 RPMs the A/F ratio varied from 10-10.3.
At the time I had a Perrin SRI, Hiboost FMIC and Apex catless down and midpipe, hood open and a fan in front of the car.
I only pulled my plugs once to change them and they didn't show any signs of excessive wear after about 30K miles.
The guys here with wideband gauges have seen lean spots, esecially when coming in and out of boost. But at full throttle 99% of MSPs out there run extremely rich.
I suppose the different boost levels could be a factor. My stock boost level was only 5.5psi. I've got two buddies here in Dallas who get 8psi stock. But the one with a wideband runs super rich when at full throttle. Maybe you've just got some freakishly powerfull turbo set up.
