Hi all,
I'm pretty sure my 2011 Mazda 2 Touring clutch cylinders are shot. In other cars I've worked on, there is usually a master and slave cylinder. However, I can't seem to find a replacement master cylinder for this car. Is there only a slave cylinder?
Also, how do I bleed the clutch since the brakes and clutch share a common reservoir? I've only worked on cars with separate reservoirs.
