- 20
Hi, i've been having problems with my clutch, so i'm told, but its kind of annoying since i have to refill my brake fluid so often.. I haven't noticed much difference since i've had the car, but i took it in to have a flex hose replaced that connects from the master down to the clutch. He said that i had a crack in a cylinder as well, so itd be pointless to replace the hose without replacing the cylinder since they're both connected. He tried pointing the cylinder out to me and said it was hard to see unless we're under the car, buuuut he didn't have a diagram to show me the part due to reloaction of his shop. I looked up the diagrams and it looked like he was talking about the master clutch cylinder and he confirmed when i showed him... The thing i'm having trouble with is, that i can see the master clutch cylinder slightly to the right of the master cylinder and it doesn't look like it has a leak at all. So my question is, is there a cylinder underneath the the master cylinder as well..? I'd really like to have my car fixed, but if i don't need to buy an extra part itd be nice and i could get it fixed. ALSO i forgot to mention, since i refill the master so often, i do spill occasionally and i hope he just confused that for the crack...
Thanks for the help, sorry if i'm extremely bad at explaining things.
