Hey y'all!
I've got a 2007 5 Sport with just under 150k miles. Here is the current problem. On take off (especially when turning) I get a clunking jackhammer sound from under the car. This tends to happen when accelerating. On occasion it also happens when accelerating over rough areas of the road. It does not happen when turning and coasting.
I had a wheel bearing issue recently and the garage that inspected the car said the sway bar bushings were fine and the struts were fine. They did mention that the both lower ball joints had a little play and were ok to pass on now but should be fixed soon. When the wheel bearing was fixed so was the lower ball join on that side of the car (passenger side).
Any ideas?
Today I came across an article that said the passenger side motor mount is a common issue with these and it sounds like that could be it but am not sure (it's under coolant reservoir and hard to see.)
Thanks.
Any ideas?
Thanks.
