BoostedPR5
well i just jacked the car up and checked it out, the tires did not move up or down. so i guess its ok to drive it to a midas or such to see if they can do a suspension test. gonna look for one who will do it for free. still need to pick up my ignition coils. any other tests i could do to see if its ball joint? i read its kinda dangerous to drive around with busted ball joints, and not as bad for worn struts. worn struts will give you uneven tire wear and not as good traction correct?
Jacking the car up at home isn't a reliable way to check ball joints. If you jack it up in the wrong place, they won't move even if they are bad. Sears does free front end checks if you're near one of them. I don't know where else does though.
