- '06 MX-5 Miata
Hi All- Yesterday I noticed that my car is making a clicking sound that seems to be coming from the drivers side of the engine. I did a search, and it seems like it might be the VTCS screw thing, but I wanted to check w/ya'll to confirm.
It started yesterday on my way to work. It started out pretty faint, and only when I hit the gas- not at idle when I wasn't moving. The car was fully warmed up at that point. It was just a constant-pace clicking that didn't seem to get faster when I hit the gas, and it went away at idle.
On the way home, though, it switched around. Now the clicking was at idle, and the car was warmed up. NOT when I was on the gas. And if I was stopped and the clicking started up, I could hit the gas a little bit and the clicking would go away. And the clicking seems to get louder as the engine gets warmer. It doesn't click when cold. I checked the oil, and it's not low at all, it's about 3/4 up to the full mark on the dip stick, using 5w30 Mobil 1. It's been about 5k miles since my last oil change.
The engine isn't running rough, nor is it hiccuping or anything like that. It's nice and smooth and still pulls hard without any other drama except for the clicking. I'll also mention that I've only got a short-ram intake on my engine- no other performace mods. And the clicking noise didn't start until after I installed my new HID lighting system. I don't think that's related, but I thought I should mention it.
Any thoughts or suggestions?
EDIT*** Took the intake off, and the clicking stopped. Now it just stumbles at idle. As if it's going to stall, but then catches itself and keeps running. Taking the car in on 1/31 to have the shutter valve replace under recall anyways.
Edit 2 *** After the dealer checked the intake shutter valve they also checked the CEL that came on. It seems that a vacuum line from the evap canister came loose, and was causing the stumbling/CEL. They put it back on and it worked fine. They also reprogrammed the PCM with the latest update, replaced a intake gasket, checked the battery, tires, belts and topped off the fluids free of charge. Not that any of that stuff needed to be done, but it was nice of them to validate what I already knew. I'm very pleased with my experience from the Mazda Gallery in Norwood.
