i just bought a P5 with 67000 miles, everything's fine so far...but today the cigarette output doesn't work... will that be the fuse burnt?? and where can i locate and replace the fuse?? please help!! thanks..
You know the ignition switch in must the ACC or ignition on position when checking? The inside fuse box/joint box is located in the left lower kick panel just forward of the driver door. Remove the joint box cover. It's the second fuse from the left on the top row of fuses. It's a 20A fuse and labeled H/CLN.
I was wondering about the max power output of the cigarette lighter... If it's a 20A fuse, can you safely draw no more than (12V x 20A) 240W? Usually the max on most vehicles is 120W, so just to be on the safe side I suppose 10A is a safe current.
