No offense, but man if you're so cheap you might as well ride a bicycle.is there no easier way to do it, the reason I ask I just recently bought the car and it had Redline synthetic, but 2 days age saw a leak. I really don't want to buy unneeded stuff. No fluid stick for tranny fluid on the "j"?
Alejo_NIN said:yet, mazda couldn't make a bolt that goes on top....now, that would had been help ful
but well, what do they care...they aren't the ones changing the oil!
There are two big bolts 24 or 25mm lower is a drain upper if to fill, fill at the top bolt. I've used a 5/8" or similar foot a half fuel hose and a funnel, it's hard to get to the fill hole with anything else.Mr.E said:Now for the next dumbass, newbie question? Where to add the fluid?
orng1 said:There are two big bolts 24 or 25mm lower is a drain upper if to fill, fill at the top bolt. I've used a 5/8" or similar foot a half fuel hose and a funnel, it's hard to get to the fill hole with anything else.
