brians_d-ride
- 2002 Protege5 with only 48000 miles
hey fellas
so basically my car did everything in this thread...
http://www.mazdas247.com/forum/showthread.php?123792173-2003-p5-wont-start
2002 P5 with only 55,000 miles on stock everything.
driving down the freeway at about 70, heard a loud ticking noise. my check engine light started flashing and then stayed on, then my oil light came on. got it pulled over. i don't recall if the car was off by the time i got it over or if i turned it off with the key.
i get it towed home, turn the key and it just spins. i pull all the spark plug boots and they all get spark. coils, plugs, and wires are all less than 2 months old. battery and starter are good. pull the valve cover and turn the key, cams and timing belt all turn. look down and all the sudden there's water coming out of the engine. not the radiator, but the engine towards the top of the pulley area. i'm assuming thats the water pump. i already made sure the timing marks all line up and everything there is good and tight.
so now i'm stuck. i took a shot in the dark and replaced the crankshaft position sensor and it didn't fix my problem. and kragen won't let me return it because it touched the car. i'm thinking the cam sensor but thats another $80 i can't return if it doesn't work.
and would it just be coincidence that this problem happens and then the water pump goes, or are they related somehow?
any help would be greatly appreciated before i start throwing money at it. thanks guys.
