HiBoost TS
Midnight,
The stock crank is actually pretty good. It is steel and will take 25 psi of boost. That is what I am running in the car. You only need the connecting rods. That's all you need. Maybe pistons if you want to run Nitrous. Stock pistons will take also 25 psi. (that's what I am running and YP5 Toronto)
The rest should be stock. Stock block, stock crank, stock bearings and gasket.
Like I said many times, the only weak part of the FS engine is the rod. They brake even in NA engines.
