Caliper Sliding Bolts P5
protege_03
2003 Protege 5
Hey gang just wondering how to remove the caliper from the guide. I have removed the top slide bolt (under the dust cap), but how do you remove the other lower one?
Bake Brakes
Yes this is on the rear. The top bolt under the dust gap requires a 10mm socket to remove. How do we remove the lower slide bolt? I don't see a bolt anywhere?
I think its just a slide pin, didn't look like both sides were bolted, only the bolt on the front. I haven't tried to pull them apart completely though, only swing them back.
I tried to pull it apart and it is no luck. Anyone know how to remove the caliper from the guide plate?
Anyone know how to remove rusted lower caliper slide (drivers rear)?
I have tried almost everything but it will not even pivot after the top slide is out.
