I was messing with my headunit settings today, and I came up with some questions that I can't find the answer to. Hopefully you guys know some of these answers.
1) Why are the subwoofer settings called Non Fading?
2) Say for example my front and rear speakers are set up with a 100Hz HPF, and the NF LPF is set to 80Hz. Doesn't that mean I am missing out on the part of the spectrum from 80-100Hz?
3) If I have a single subwoofer, does it matter which way I have it connected(positive/negative wires) in reference to the rest of the speakers?
4) I read somewhere on this board that equalizer settings on the head unit should not be tweaked very far from 0, since it will cause ditortion which blows speakers, and that adjusting the bass should be done through the NF level. Won't the NF level cause clipping too? What about the amp "sensitivity"(is that the same as gain?) If I turn up my amp's sensitivity all the way, will that also cause clipping/distortion?
5) Should the NF LPF be set at the high end of the frequency response for a subwoofer, or something different?
6) Anyone know what the frequency response for the JL 8w3v3-d2 is?
