Hello,
I am new to these forums. I just bought a Protege 5, and it turns out the thing is a total POS. The owner lied about all of the problems it has, and now I have to deal with it. The car has been in an accident, needed new timing belt, gas gauge broken, etc. So maybe you guys can help me out. Sorry if some of these questions have been asked. I searched the forums but could not find answers, and I wasn't able to download the service manual.
So here are some questions:
1. When I remove the oil fill cap on the valve cover, I can here a "blowing sound", and I can feel air blowing out of the hole. My first thought is that it is blow by. But perhaps it isn't? Do your engines do this? When you remove the oil fill cap can you feel air blowing out of the hole?
2. I am guessing that the jackass I bought the car from disabled the check engine light. It does not illuminate when the key is in the "on" position. What is the easiest way to access the light bulb so that I can replace it. Again, I can't download the service manual to find this out.
3. The gas gauge is incorrect. Does anyone have any experience with this? I have seen on some cars where it is not the float that is the problem, it's some other random piece of electrical crap that needs to be replaced. Is this the case with this car?
4. The top end seems to get noisier when the car warms up. It is not super loud, but noticeable when you are under the hood. Is this typical?
5. I just replaced the timing belt, tensioner, tensioner spring, idler, and water pump, but there seems to be a slight "whirring" sound coming from the timing system. I don't know if it was there before the replacement because the belt was loose and knocking. It is not loud, but it is noticeable if you are under the hood. Has anyone heard this sound before.
Thanks for any help, and thanks for the good writeups on timing belt replacement. It really helped me out!
