DrummerJim50
- 2006 Acura RSX Type S
I installed Bronzoil bushings and a B&M in my car a few months back. I've had a problem keeping the bolt tight - the one that connects the bottom of the shifter to the rod - so it starts rattling, and if it gets too loose it starts squeeking a little when I shift. It started rattling again last week, so I was going to take out the bushings and clean them up (looks like it started corroding a little), put some grease on them, and put it back together and secure the nut with loctite. I put it up on the lift and unscrewed the nut but the bolt that goes through the bushings and shifter won't come out. I used some pliers to pull it, squeeze it, used some WD40, banged on it as much as I could, but it was no use. Anyone else had this problem?? It's not life or death, but I'd like to be able to take it apart if I want/need to.
