TheBryGuy said:Oh....I might do this then....how much did you get the calipers for and where from?
i just though of this, i just changed mine stock as wellKanseiZM said:When I need new front rotors/pads (not soon, did pads last July and rotors in November) I'll definitely look into this and probably do it unless the prices for different "big brake" (relatively big at least) kits come down.
are you 100% surelow_psi said:simple bolt up operation, the hubs are the same.
good pointgimpo2 said:^^ yep, get v6 626 s***. i dunno if there would be a mark up if its sold as msp parts
Alejo_NIN said:does this means that the v6 626 front rotor set up is the same as the ones in the msp???
if so...mazda went cheap again....those fuckers!
