bradboyd80
- '12 Velocity Red MS3
Ok, first off, I searched and can't find anything related to a bouncing idle (plenty on low idle tho). To get it out of the way, the mods are in my sig, and as you can tell, no real mods other than a forge bpv and exhaust.
So this morning I was driving to work. Well once the car warmed up, when I would stop at a light or whatever, the idle would drop to the point where it would almost stall (the car actually stuttered like it was about to stall), then jump back up to normal, almost stall again, and then settle back at normal as if there is no problem. WTF? I've cleaned the maf and egr already, so could they be going bad? I've also pretty much triple checked all my vacuum hoses, and my gauge seems to be fine (reading about 17 at cold start and 20 after it warms up). I plan to take out the egr this weekend and take a look to see if there's a problem (heard it can get stuck open or something?). Any other advice on what to look for, or try?
Thanks!
Thanks!
