some ppl said that they felt gain from iridium plugs
I didn't "feel" any power gains from the NGK Iridiums but I got a ~2mpg increase in my mileage. (I have to check the second tankful to verify this..but I was impressed with the mileage increase)
FlyinMSP said:I have used the Bosh Platinum +2 on my MSP without any problems. But I'm using Denso now
Rac3rX said:Yeah Im running Denso too, and never felt better, with the Nology plugs the revs are very smooth, idle is extreamly stable, the needle just points at 500rpm without budging in the slightest, and goes right to 750rpm when you turn the wheel to kick in the power steering.
Denso's are a bit expensive but MUCH cheaper on E-bay.
cop1976 said:I just purchased the Bosch Platinum +4 spark plugs for my P5. I havent installed them yet, but should be doing so in the next day or so, along with an oil change and a EGR valve cleaning. I'll let you know what happens.
My vehicle was sputtering when I came to a stop almost to the point of stalling and the RPM's would just drop. It is apparently a common problem in the Protege 5. In the "How To" section there is a a step by step guide on how to clean the EGR valve. It builds up with carbon due to our rich fuel burning and can gum up the valve. I just removed mine today and cleaned it up with throttle body cleaner and greased the valve and spring and the problem is solved! Tomorrow I am replacing the plugs and doing an oil change (switching to Synthetic).ZG77_OzZ said:EGR not to sound stuiped but what has to be done with it?
RaiderMP5 said:NGK V Power OEM work best. I tried them all. NGK is what came with it, and after burnign through a few sets of expensive ones, back to the cheap reliable ones.
ZG77_OzZ said:nology what is so good about there system?
i12drivemyMP5 said:Ummm, still wondering what oil/gas people are running to get EGRs to clog. I got an extra one on a manifold I got to eliminate VTCS & it was OK but cleaned it a little anyway. At 50k or so I pulled mine off to check it out (idle was OK) after all the threads about them & it was no more clogged than the one I had cleaned. I run castrol syntech oil, keep the K&N clean, use shell reg gas (10% ethanol mix)almost always, a shot of acetone every now & then & not to be threadjacking.....long reach ngk plugs (ZFRs) = No carbonfest. Are people running their s*** at 4-6000 rpms all the time to accomplish this or what? Don't get me wrong, I visit there on occasion but my car lives mostly in the 2.5-3.5k range.
