Sadly another post here.
As the title says. Yesterday as I went for a twisty drive through the mountains my car decided to just stop making power. Up till then my car had been running great.
I first noticed that when I would let off the throttle the car would lurch/buck pretty hard. Very shortly thereafter I found that preboost I had the usual (unimpressive) power but as I built boost I could hear it boosting like normal but it seemed like my power went down dramatically. I limped it out of the hills (nowhere to safely park and no cell service if it ceased running) and even downhill it would just brickwall around 3.5-4k. On a flat section it basically felt like it was a 50hp car. It also seems like my car used an excessive amount of fuel for the miles it went (I track my mpg) normally full to low fuel light is about 310 miles and at 190 miles it was already just under a quarter tank.
At idle the engine sounds fine, nothing particular in sound or performance. Boost was going to 5psi (what my forge wga came as...stock the site said) and vacuum was 18 idling and 20 while driving w/o throttle. I have the Joembc fpr (and this is far to dramatic to be the usual hesitation etc).
Of course, it has not thrown a single CEL to help my track the problem.
I checked vac lines and for everything obvious, such as loose spark wires or obvious holes in my boost pipes. With it idling so well I am not sure if a coil could be bad. I have not had time to tear into anymore but would love ideas anyone has for when I get home in a couple hours so I can hopefully pinpoint and fix this issue asap.
When I get home I will pull the plugs, check the coils and look around more carefully, but again nothing was really apparent yesterday.
