boost gauge help
coyfish
Forgive the newbness but I just got this used digital gauge from renzozuken :).
I already have a cheapy manual guage but im not sure how to install this one.
I t'd off my vacuum line. I have a tube from the T to the sender box. The sender box has a black wire with 3 ends (red, black ,white).
The gauge has 4 wires (red, white, black, green). I guess I need to buy some wire to connect them but im not sure which one goes where. Any help would be much appreciated.
Also just FYI I did a search but couldn't find any digital gauge installs, just the basic manual ones. If you happened to come across a HOW TO please let me know ! Thanks in advance
In car electronics, black is usually ground. In home wiring/AC circuits, green is a ground.
Are there connectors on these wires? Basically, the wires from the sensor get routed to the gauge, and the gauge itself should have a different cable with the following wires: a 12V Batt (usually yellow), 12V Switched/Accessory (usually red) and a ground (black)
I would contact Prosport. They were pretty quick at responding to my emails. Just tell them you removed it for a dealer visit and lost the instructions. Don't tell them you bought it second hand.
Yep I sent an email to prosport. Thanks for your help everyone.
So to connect everything up just use generic wiring?
Just go buy yourself some wire at the local Radioshack/auto parts store. I'm a fan of color matching the wire to the device, but you don't have to. Hell, you could use the same color wire, just label it.
Download the attached file:
  • DASH AREA INSTALLATION INSTRUCTIONS FOR PROSPORT 52mm BOOST GAUGE.doc
You're welcome ... obviously you may want to install elsewhere but the rest of the instructions for hook-up should be fine.
one more problem. Everyone with prosport gauges have red, black, green, white wires. Instead of the white . . . I have yellow.
Anyone know where yellow goes . . .
red - ign power
black - ground
green- sender
yellow - . . . . ?? I assume constant power . . .
