I have stock rims, Bridgestone-Potenza RE760 Sport tires (stock size), inflated to 33 PSI when the tires are warmed up. They preformed impressively at the track the other day (I just had them installed), but I'm wondering if there is an optimal tire pressure that would give me best cornering grip.
I'm asking because there were some guys (with older BMWs) at the track who had their tires inflated (just for the track occasion) to 40 psi - they said: to reduce tire roll.
My suspension is stock, with exception of the rear sway-bar bushings relocation kit (klunk fix) which reduced sway-bar flexing.
The tires I have, have reinforced sidewalls. They read: "max PSI under load: 50".
Turbo is running at about ~9.5 psi.
The track I visited, and will probably continue revisiting, has turns that I end up taking while in 2nd gear, although mostly in high-RPM.
