Hi All --
Okay I'm ready to tackle the interior lighting. I wanted to confirm the interior lighting as some folks have tried bigger sizes and fitted fine. For example, the map lights indicated 28mm but some people have tried 31mm and worked.
Also where should I buy the LEDs if I want the brightest? Superbrightled? JDMtoy? Amazon? Thank you!!
- Front headlights/fog lights: H11
- Front turning signal : 1157NA
- Front drl (HALOGEN): hb3u 9005
- License Plate Bulb: 168/194/T10/W5W Wedge bulb
- Cargo lights: 28mm Festoon bulb, labeled 10D
- Front Map lights: 28mm Festoon bulbs, labeled 10D
- Rear Map lights: 28mm Festoon bulbs, labeled 11B
- Vanity Lights: 29mm bulbs w/ flat end caps (looks like old style fuses)
