Nice work! are getting the box built or just changing the valve body?
Just the valve body & shifter for now. After having the car off the road for so long doing the turbo conversion, I want to be able to drive it as much as possible before the gearbox comes out.
Here are the fruits of my second day off work!
I have been wanting to try different thermostats for a while as well as fix up some stuff that I did during the turbo upgrade which I wasn't happy about. I bought two Tridon high-flow thermostats. These are for an FD RX7
The Cosmo uses two thermostats. One which is 97 degrees and the other which is 82 (I think). The 82 degree thermostat is controlled via the solenoid rack. That is why there is a VAC line running to the thermostat housing. The idea is that the 82 degree thermostat remains closed most of the time. The diaphragm in the top of the thermostat housing keeps it shut via positive pressure. This means that most of the time, you will be running around on your 97 degree thermostat. I've been told that this was mainly for emissions.
Here you can see the exposed thermostat housings. The torque that you need to undo the four bolts is pretty huge so don't be afraid if you need to employ a breaker bar.
The rear one should be the 82 degree thermostat.
Note that you WILL need to reuse the black rubber seal which is used on the factory thermostats. These can easily be removed if you heat the rubber up in hot water. Be very careful not to break or crack these seals.
Below you can see I have put the rubber seals onto the outside of the new thermostats...
...And in...
I polished up a new thermostat housing. The reason why I needed to buy a new / secondhand one is because when I installed the fuel system, I thought that I had to grind down part of it to get enough clearance for my AN8 fuel fittings... Turns out I didn't need to and I just made a mess instead. I also lost the use of the metal space which holds the throttle cable up. This meant that my throttle cable just chilled out on top of the turbo beanie - not ideal or chilly at all.
I still had some clearance issue which required taking a chunk out of the throttle cable support piece. Die grinders are AWESOME, but boy do they make a mess.
And here is the final product.
So how did the new thermostats go?
Well not as great as what I had hoped. I got a maximum temp today of 91 degree in stop-start city traffic with 34 degrees ambient temp. Average was about 87 degrees. I was hoping to be able to keep it around 80-85. Keep in mind this is an improvement though.
