bent trailing link
changedman
Banned
Contributor
2001 Mazda MP3
i was changing tires to winters today and noticed that my rear passenger side trailing link is bent- quite a bit. it is almost rubbing the inside part of the tire. it shouldn't be like this-
i had my bushings replaced and the dealer said nothing.
should i take it in, or is it not that bad or is it not really required.
should this be warranty work?
The dealer probably jacked it up improperly.
1244 (msporange
i have appt tomorrow at 410p, is it something where i shouldnt drive the car?
will they just bend it back or replace it?
If the dealer tries to screw you, by charging an arm and a leg, you might want to look at AWR Racings trailing links. I just put them on this weekend and they really improved the handling of the vehicle. Real easy to install, as well. They are only$85.00. www.awrracing.com
Patrick
Not sure what a stock one runs, but make sure you don't jack your car up from these as they are very flimsy.
thanks. now, how hard is it to put them in? DIY thing? I mean sheesh, it looks like just two bolts.
Latest posts
