Hmm...Well, I was sitting in the car with the engine OFF. Moved the steering wheel quickly (not far mind you) and was getting a clunking noise. Does that point toward the tie rod end or the sway bar link - i'm guessing the tie rod end?
Again, I was sort of under the car, and the inner tie rod end seemed solid as did the outer, but I'm no mechanic.
The bottom end of the sway bar link looks in bad shape (looks ripped) , but like I said, no movement by hand.
Every protege I have been in has that clunk from the driver side wheel, I don't know what it is, but I didn't see any work parts.
You can't see when tie rod ends go bad unless its already too late. You need to lift the front of the car and feel any slop in the components.
Replace the links, they aren't expensive.
My moms car had brand new links and would clunk really loud after a week of driving. 6 months later I discovered that 1 of the nuts from the link was loose. The only way I could tell is If tried to tighten it further, moving it by hand showed NO play. Once I tightened it, It was fine.
