I have recently performed some tests on my alternator (which I suspect to be faulty). I took it in to a couple of local auto parts stores and it tested good at both places (showed N/A for diode check). I decided to check the current output from the amp and here is what I found. At idle, with all electronics off, the current was approximately 12 amps. At 2000-2500 rpm the current was approximately 12 - 12.5. Still at 2000-2500 rpm, the lights were turned on and the amps jumped to around 40 amps. The blower was then turned on and the amps jumped to around 50 amps. I had the revs increased and the current maxed out at around 58 amps. Here's where it gets really funky.... I switched my ammeter over to a/c and sure enough i measured 3 amps (A/C!!!!) at 2000-2500 rpm. I know these things should NOT be putting out a/c.... how could it test good with a funked up prob like this. This alternator is most definitely bad isn't it?
