Easily done yourself. You need ramps or jack with stands, and a few sockets, 17mm and 19mm if I remember correctly. A torque wrench is reccommended, but not absolutely necessary. You can remove the old and put in the new without supporting the engine.jweidler_1130 said:How do you guys install AWR mounts yourselves? Do you need a crane to lift the engine, or is this something that can/should only be done in a mechanic's shop? Please advise.
SwampAss said:There was talk about making these with a black poly insert. Did that plan ever come to fruition?
