MTX regular protege, or msp axles
Transmission try to get one out of an 03.5 for upgraded forks i think. its upgraded something
clutch upgrade here
flywheel possible upgrade if you're going to n/a, turbo you might wanna think about it.
manual ecu (i was told by igdrasil that if you leave the auto ecu in the car will still work but you will get a blinking tranny light and your speedo won't work) the car should still work without it
manual engine wiring harness (you can hack into your existing harness and splice in the pins for the tranny sensors i.e. speedo gear) also try to get a regular manual protege, not an mp3 it is missing vtcs and cruise control, msp will not have cruise) car should still work without it
Manual starter engine harness there's a seperate harness that goes from the main fuse box thingy to the starter. it also has the connectors for the speedo sensor on it. so you'll need it if you want speedo
shifter
linkage
that piece where the ball of the shifter sits i think its a whole little ball joint assembly type thing. you'll have to look
shifter bushings just get kartboy
clutch pedal assembly
fluid line from master cyl and slave cyl
steel line from slave cyl to clutch line
clutch line just get some SS braided
manual engine mount side mounts both sides the engine is actually moved over to the drivers side a little in manuals
rear motor mount bracket on manual tranny
brake pedal its not as wide as the atx one
you might as well upgrade to AWR motor mounts and possibly get the side mount inserts.
mtx main bearing support plate bottom of the engine. it has a spot for 1 transmission bolt on it. can possibly go without it. I rebuilt my engine at the same time so i just popped it on.
you still will need misc gaskets and bolts that go inbetween all the things and s***.
thats all you need to make it work. for looks you need the center console piece, shifter boot, plastic base off stock boot, and knob.
You will need to rewire the main starter wire from the dash harness to the ecu harness in the cabin to get it to start since they use different slots in the connector.
Also your reverse lights and speedo won't work without rewiring. I still haven't done it yet.
The ATX Dash harness has 2 connectors that don't match up to the MTX engine harness so you will need to cut off the connectors on the ATX engine harness and resolder them onto the MTX engine harness inorder to get your gauge cluster working. I am unsure if my ODBII port works. So you might lose your ODBII port funtionality. I haven't checked yet since my Haltech resets it everytime. You will fail emmisions if your port doesn't work.
i think thats it... if something is missing its really small
