Last Saturday while my wife was driving the vehicle, it suddenly made a sound and the transmission malfunctioned. Although the car was in drive, when she pressed the accelerator it revved as if in neutral. She coasted to the side of the road, turned the vehicle off and restarted it. The transmission seemed to work normally again but the CEL (check engine light) remained on. After a lengthy wait for a tow truck (poor marks to Mazda's emergency roadside service for this part), we took the vehicle to our favorite local Mazda dealer. They ran it through diagnostics but couldn't determine the problem. Monday morning, they called MazdaUSA and everyone went into high alert (much like what was described in another thread in this forum). A Field Service Rep came, corporate was involved, etc. At first they thought that the transmission might need to be replaced (ugh, as there obviously aren't any sitting in local inventory at this point) but after three days of testing and evaluation, ultimately concluded that most likely the problem was some metal shaving or other debris had gotten into the transmission solenoid valve during manufacturing. They removed and cleaned the valve, performed a flush of the system and replaced the transmission filter, and that cleared up the issue (as best as they can tell).
Kudos to MazdaUSA for jumping into the situation and assisting with the resolution, as they obviously were concerned about a potentially bigger problem with a new model vehicle. But if you have a similar experience, mention our situation to your service folks and hopefully it will help get yours corrected quicker.
