Alright guys it's getting hot in Atlanta already and I know my way around AC systems but I'm completely stumped right now.
The fan control is working no issues there. Fuse for the AC is also good. Clutch engages as long as there is some freon in the pipes.
I vacuumed the lines and only got about 10 lbs mercury with isn't anywhere close to perfect.
So I know I have a leak somewhere. I added freon to the system. 1 can just to see. Had cold air for maybe a day.
Earlier I added UV dye to the system and ran it for close to an hour and checked for leaks.
I have not found any dye in the engine compartment.
Vented the remainder of the dye and freon out of the high side and alot of the dye came back out.
My current guess is the expansion valve is plugged and needs replacement, but would that cause me to have a leak?
Any help is appreciated, I spent some time looking through threads to see if there was an answer to my problem.
Thanks guys
~Alex
Thanks guys
~Alex
