Aftermarket radio replacement issues
pmoon00
Mazda Atenza Sports 4WD 2006
Hey guys,
I need help putting in my aftermarket single din radio into the car. I have successfully removed the factory double din radio. I bought a single din radio and another single din pocket to replace the gap. Using the clips/brackets off the factory double din radio, I can't get it back in. It's like the clips/brackets can't flex in far enough to clip in.
For whoever has replaced their radio, how did you put the new one in? Did you buy any special mounting accessories?
Any help would be much appreciated!
There is a protege specific kit you need. Uses the cage that comes with the aftermarket radio and should just snap in
Latest posts
