Aeroforce Interceptor Gauges and Dual Pod
Status
Not open for further replies.
Never thought I would post these for sale but here it goes. A couple of months ago I organized a group buy for these gauges and ended up buying 2 of them. I also got in touch with block8head and got a dual gauge pod made for these gauges (the dual pod gauge is 52mm).
As you can tell, everything is in great condition and would be great for anyone wanting the ultimate in monitoring for the speed3. The Gen2's were unfortunate in not having a multi display monitoring solution like the dashawk provided for the Gen1's.
I am not going to get into all of the details of the gauges but they can clear codes, record parameters, and throw up warning signals based on custom settings (like set KR or fp with warning lights).
These gauges work for gen1, gen2, and cx7's.
Check out the website for more information as well.
Aeroforce Technology Inc | Products - Interceptor Mazda Order
My asking price for the bundle is $425 shipped for the gauges and dual pod. Mind you that these go for $400 just for the gauges and another $120 or so for the vent pod. (windshield washer fluid not for sale)
I would be interested in a trade--If you have a single vent pod and a boost gauge, I would be open to negotiating. Other than that, I don't need anything else. I will not separate the gauges either because these come with the dual connect cable that would be otherwise extra.
Please let me know if you have any questions.
Some of the parameters:
Mazda (CAN) Vehicles CNI series gauges
1. INTAKE AIR- Intake Air Temperature
2. BOOST TEMP SENSOR Calculated actual boost air temp. based on sensor output
3. COOLANT TEMP- Engine Coolant Temperature
4. TRANS TEMP- Transmission Temperature (gas powered automatics)
5. RPM- engine Revolutions Per Minute
6. MAF SENSOR LB/M- Mass Air Flow (lbs/min)
7. DIRECT INJ PRESS Direct injection fuel pressure
8. INJECTOR PULSE WIDTH
9. INJECTOR DUTY CYCLE 0-100%
10. MANIFOLD PSI- Manifold Air Pressure (psi)
11. THROTTLE POS PCT- Throttle Position percentage (0-100%)
12. THROTTLE VOLTS- Throttle Position sensor output (0-5 volts)
13. MILES PER HOUR- Miles Per Hour
14. KNOCK RETARD- Knock Retard (degrees)
15. IGNITION ADVANCE- ignition timing advance
16. SHORT TRIM B1-short term fuel trim bank#1
17. SHORT TRIM B2-short term fuel trim bank#2
18. LONG TRIM B1-long term fuel trim bank#1
19. LONG TRIM B2-long term fuel trim bank#2
20. COMMANDED EQ RATIO Commanded Equivalency ratio
21. LAMDA Wideband O2 sensor equivalency ratio
22. A/F RATIO Wideband O2 sensor displayed as Air/Fuel ratio
23. O2 CURRENT Wideband O2 sensor current
24. BATTERY VOLTAGE- Alternator/battery output voltage
25. ENGINE LOAD-calculated Engine Load (0-100%)
26. Calculated Engine Torque (Auto trans)
27. Miles Per Gallon instantaneous fuel economy
28. Calculated net horsepower
29. VALVE TIMING Valve timing in degrees
30. Analog 1 analog input #1
31. Analog 2 analog input #2
interested in pod only, shipment to 77345? Send PM
New from Blockhead is 120 with shipping
Status
