I have not noticed any settling of my H&Rs (assume that's what you installed) in 18 or so months. As for your rear alignment, yes, the settings often come out within spec camber-wise, but I guarantee you they're on the negative outer limit of acceptable and you will get some degree of inner shoulder wear. In my experience, you'll get it on the front too, though not as pronounced. It's actually easier to correct the front camber (with SPC cam bolts http://www.tirerack.com/suspension/...el=CX-5&autoYear=2013&autoModClar=Touring+FWD) although no one here seems interested in doing that. I'm probably going to do it when I change tires in 5k miles or so as it's such a no-brainer.I had the springs put on the other day and the shop was able to get the camber in the green without the camber arms. Hanging on to them should the springs settle more (though they are used springs).
