on the freeway with the AC blasting in my 06 Mazda 5 when I heard something break with a snap followed by a long sigh. The AC quit working. A little while later, rasping whine from the engine like a loose belt.
The bearing on the AC pulley was toast. And the AC solenoid fuse blew. The compressor itself would not turn, but i was able to free it up by turning it backward. So I replaced the bearing on the compressor, a heck of a job in itself. But after that, AC would operate but not cool. Finally removed the compressor and took it apart.
Turns out the compressor is a vane type, with 3 vanes made of brittle sintered aluminum alloy ceramic. The vanes slide in an out of an eccentric shaft. Two of the 3 vanes were broken clean into two pieces each. No shards or burrs, just snapped in half like cookies.
Awaiting a new compressor for $530, will update after I install it.
