For a stock motor an internal wastegate will work fine. They are very simple and easy to adjust with a boost controler but not rebuildable. An external are usually for higher HP figures. They do not have teh boost creep symptoms as bad as internal gates but if you use a boost controler boost creep will not be a problem anyways. Externals also require alot more plumbing.
