- Protege5 2003
I think the problem is most likely what you originally said, there is a tiny contact region.
Probably that's it. Probably. It's still worth taking a look at the resistor pack. If nothing else at least inspect the contacts and make sure that they aren't dirty or corroded. You've already seen what an iffy contact can do in this circuit. It shouldn't take more than 5 minutes or so to do this, as the pack is just behind the glove box.
