OK, here goes, I wasn't sure where to put this so I stuck it in the Mazda/Rumors section but I hope you techies can help me out a bit so I can sound semi-knowledgeable when I go back to Firestone or a Mazda dealer. I did a search on "alternator" but nothing really relevant came up so here it is.
I have a '98 4 cyl. 626. The symptom is as follows: The charging system light stays on and the alternator hasn't kicked in. When it does, I can feel the engine shudder and the charging system light turns off. This only happens when, for example, we drive the car to store 1, shut the engine, come back and drive to next store, shut the engine, then come back, and boom, charging light stays on. In some cases it can take up to 10 minutes for the alternator to kick in.
The belts are not loose - I can see that everything is spinning on the engine.
Some more background:
The problem started with lots of squealing in the alternator about a 1.5 years ago. Eventually I had it replaced with a remanufactured alternator at a Firestone Svc. Center. I've taken it back 2x with the same complaint as above - they rechecked everything and couldn't find a problem. It's now been a year (1 month over the warranty from Firestone) but I still have the problem.
Any suggestions/help will be appreciated from all of you knowledgeable folks out there. Thanks!
