500 awhp build if i can find a turbo lol
Bishop9d4
Ok people need a bit of help. Im going to break the 500awhp barrier I have everything but the turbo.
List of NEW Mods. (current mods in sig)
Wiseco Pistons
K1 Rods
CPE Mani
HTP 4 inch intake
HKS Twin Power
Tial 44mm waste gate
CPE Stage2 clutch
5th and 6th injectors
Speed Performance stage 2 cams
Crower 65lb Springs and retainers
Wilwood Big Brake Kit
Ok the problem is I can decide on a turbo. I was looking that the GTX 3576r and the PT 5858 and 5862
Turbo Compressor ind diameter Compressor exd diameter Turbine diameter HP
GTX3576R 58.00mm 76.60mm 68.00mm 400-600
PT5862 58.00mm 76.20mm 71.00mm 600-640
PT5858 58.00mm 76.20mm 64.90mm 600-620
I see the numbers I understand the numbers but Ive been reading that the gtx will spool but still have it up top and the 5862 wont. But i know the EVo guys are saying the 5858 and 5862 will blow the GTX out of the water as far as faster spool and top end. Does anybody know if that is true? Will the bigger turbine on the 5862 spin it faster or cause lag? Will the 5858's smaller turbine diameter cause it to tap out on the top end. And also the GTX 3576r comes with a .82 a/r and the PT turbos only offer a .63 a/r. im looking for the mid to top end power as my redline should be 7500 or better with a P and P. I could use some real help. Please leave the smart ass comments to yourself im not a noob to cars just to mazdas im used to building hondas and evos and not having to put up with DI. THX in advance
Latest posts
