So I'm new to the world of the 323 gtx although I've had a couple mazdas. I picked this car up a couple days ago car seems awesome has a lot of really nice mods
Here's the car pretty clean minus the roof but i will be removing the previous owner's work he did and install a Manuel moon roof or completely delete it
I will be repaint the car specially since its bondo free at the moment
Mods that came with the car
galant vr4 brake upgrade
Corksport upgraded intercooler
Custom intake
Spec clutch and lightweight flywheel
B&m shift knob
Plx wideband plus plx box
Grant wheel
Konig r wheel
GAB Dirt trail shock and springs
Chipped ecu reich racing also came with a none chipped ecu
Hks f con
Hks evc
Hybird turbo stock exhaust housing thunderbird intake housing
arp head studs
Long neck crank i think he said help was crank walk
So far that all i can think of or found
The trans looks and said to be rebuilt the head was rebuilt the block had good compression.
The block need to be set to tdc and cam gears aligned to finish the timing. Change the fluids and running the vac plus intcooler plus and we can start it
Stock ecu
Chipped currently installed. I need to figure what tune is set for the chip i heard there reich made a couple different tunes
Engine bay
the wheels plus vr4 brakes
plx gauge
plx box and the reich chipped ecu
hks f-con tuner
hks evc
interior
2.5 catted exhaust
Custom intake
B&m shift knob
Grant wheel
Konig r wheel
Hks f con
Hks evc
arp head studs
Stock ecu
Engine bay
plx gauge
hks f-con tuner
hks evc
interior
2.5 catted exhaust
