New CX-5 owner [and to this forum]...Hi!
So far so good...but I found it amazingly painful to setup my favorites on SiriusXM - once defined it seems ok to select.
The root cause is moving to the required station seems to have to go through the menu that lists all station [always from 0] then scroll and select station [easy then to add by holding 'favorite' button].
When I have used Sirius on other manufacturers cars before, there is often some easy way to go up/down a station e.g. if on station 120 then will goto 121, but this only seems easy here if you have these on your favorites - I sometime just want to goto adjacent stations to see what's on.
I didn't get any quick start or Sirius manual with new car and wondered if I'm missing something blindingly obvious.
TIA
TIA
